Creative 7.1 Gigaworks speakers
Nasty_Savage
Extremely [H]
I'm using the onboard 7.1 sound from my Asus board, but the stupid way Creative made the speaker wires there's no seperate cable for the side speakers. I tried putting a sperate cable for the side from the woofer to my motherboard but I only get sound from the left side and the right is muste. Its not the speaker or the wire because I tried it in other ports.
Any ideas?
Any ideas?
It's not the side that's screwed up, it is the "Rear Center/s". There's normally four connects, F/RL, Side RL, C/SW and Two Rears for 7.1 or One Center Rear for 6.1. Creative Combines the Center, SW and Rear Centers in one connector.
Find a cheap SBLive 7.1 even it couldn't suck anymore than OnBoard:)
Poop. Its prolly not worth getting this revision until they flesh out something that's Vista 'native' So there's no way around this for onboard until that happens?
But why wouldn't some of the Vista software work with one of the Cheapie SBLive 7.1 cards?
I don't believe there are Vista drivers available for the SB live currently which pretty much precludes it from being used by the os, right?
There are a bunch of gaming issues and driver issues I don't want to get into yet until their next gen cards (where Creative screws it all up again...i wish I could just use an M-Audio card if I can't get the speakers to work with a non-creative card)
Direct questions to Moofasa? I don't use Vista.
I'm having the same issue. I have XP and I have the Asus Striker mb with 7.1 sound, but it too won't work with the gigaworks cable and speakers. Creative should have offererd a cable that could be used with a normal sound card, but NO. If you really want 7.1 from gigaworks setup, you need to use a creative card, and that suxs! I'm thinking of selling my gigaworks speakers and buy some logitech 5.1 speakers. That way I can connect to ANY sound card. Being these gigaworks speakers are only 1 year old, this pisses me off!
If anyone knows of a solution, other than replacing my speakers or buying a cheapo cl sound card, please let me know.
Thanks,
per [H]ardforum rules - (25) You are allowed one signature per post. A signature section is supplied for that usage. No one wants to see your name on your posts multiple times as it is annoying. --- magnetik
How about getting 4x 3.5mm plug stereo cables? the subwoofer itself has 4x stereo jacks
You'd need a 4 pin Female Cable. This could be and extension cable for an Audio/Video 1/8" to RCA. Then it would be very easy from there. I had (they don't work anymore) the Megaworks 650 6.1s, same problem. Instead of bitching about it, I'd get a SB card or sell the speakers.
check the Creative Online shop. I just ordered the 4x 3.5mm cable for onboard and non-creative soundcards. Will cost you about, what.?.. $25 with shipping and tax?
cheaper than a creative sopundcard or other speakers.
Yes but this person needs the Female cable with RCA's on the other end. The Gigaworks only has 3 cables. F L/R, R L/R and instead of two more 3 Pin stereo jacks, it has one Combo 4 pin jack. It carries not only the signal fro the Center and Sub but also the Single Rear Center for 6.1 or Two Mono for the Rear two for 7.1.
If you look at the Orange Jack, you'll see that it has 4 segments instead 3 like a stereo jack. As folks here beat people over the head with only needing 3 stereo, I was trying to say NOT if you plan on 6 or 7.1 sheesh!. So they would need on Female 1/8" Jack with the same 4 contacts or pins then use a mono splitter depending on 6.1 or 7.1 usage.
http://www.creative.com/products/product.asp?category=1&subcategory=16&product=14191&nav=connections
Same cable are used on all Creative's products. Apple IPod also uses a version of this for the remote I think.
Okay, so... I might have misunderstood things ...but if he needs to connect the S750 to a soundcard other than Creatives then he needs this: http://uk.europe.creative.com/shop/product.asp?category=12&subcategory=0&product=949& ( Watch it...EU store ) All the side-channels are seperated except for the front and sub.
Was thàt not the point? Separated chanels instead of creatives 4-contact-3.5mmplug?
O well it's late and i'm having trouble here :) so i'm a bit confused.
Okay, so... I might have misunderstood things ...but if he needs to connect the S750 to a soundcard other than Creatives then he needs this: http://uk.europe.creative.com/shop/p...0&product=949& ( Watch it...EU store ) All the side-channels are seperated except for the front and sub.
You are not confused at all Lone_Bullet. That is exactly the cable that is needed to connect the Gigaworks to a 4x stereo soundcard, nothing else is required.
Thanks guys. It really is a bit confusing. Thanks for the links. I'm not able to purchase that cable from the US, and I wasn't able to find on the US creative labs store. Is this cable new, and just not yet on the store?
Replacing the cable sounds like a good solution to me.
Please let me know if I can buy this cable from somewhere else.
Thanks again!
Ok, went to RS and got 4 mini stereo plugs, just like the one you are recommending. I have 4 plugs on my gigaworks s750 7.1 and 4 on my onboard sound card. No go, I have no sound out of my side speakers and the hole thing sounded bad. Something tells me I need the creative labs cable, which isn't available on their site.
crap
So Do you connect your Sub to a discrete Sub Out or do you connect it between your fronts? If you connect it in between you front speakers skip my post? If you use a Discrete out you'll know what I mean.
URL=http://www.putfile.com/pic.php?img=4994117]
[/URL]
My Megaworks are 6.1 and yes I can use 3 Stereo Jacks as you say. Then most of the time all I'm getting is bass from my fronts and rear explosions don't come accross as define. It's not bad for music but not the best for Games or even Movies.
So that's why I said you need a Female plug for this!
The 4 segments on this Connector are Front Center, Rear Center (Two monos for 7.1) Discrete Sub and common Ground. If you look at the Back of a Receiver with Analog 7.1 in, you will see a Discrete Sub InPut and NOT like my MegaWorks 6.1s that only kind of works:)
http://www.harmankardon.com/3d_swf/AVR435.swf
Any more Questions?
crap
Make sure you have a 7.1 source.
crap
Are you sure you have signal coming from the side channels on the integrated sound? on my MB I have to switch that jack between line-in or side channles. Test that output with the front speakers to verify. And what artifacts made the sound bad? background noise, attenuated frequencies, clicks and pops, sounds coming from a wrong channel?
Unless the quality of those RS cables is really bad, I don't think the CL cable would make any difference, I have connected a 4-4 CL cable from a DDTS100 decoder and it's just four cables attached together.
You can also test a 5.1 configuration with the bundled 3-4 CL cable, the extra pole in the miniplug is grounded when it is connected to a stereo jack. That way you can see if it sounds bad because of the cables or because the onboard sound needs some tweaking.
Donny....as I see it in your pictures you are trying to connect you source to your Subs ( with integrated amp ) speaker outputs.... post a complete picure of all the in and outputs and i'll mod the pic with signs how to connect it.
If you were goint to connect those speakers to that Hi-Fi Amp you have then I suggest you buy other cables , like 3 " 2 RCA female Mono to 1 3.5mm male Stereo " plugs and then 3 stereo RCA cables. Or simply make them yourself :D, soldering is far from hard to do.
Steve, Make sure Windows is in the 7.1 mode. Also double check the connections, mistakes are easy to make then excited about new hardware ^^...
Coïncidence is that I just ordered the same thing for my future mobo. If you're not helped in a few days i'll PM you with posts how to set them up ( onboard mobo to S750 )
The Creative Cables are in the " Shop " -> "Accessoires" -> "Cables" Make SURE you're not on the Soundblasters site but on the main Creative site.
***Edit*** Crap you're correct can't find them either on the US site.....damn, sorry man...you'll have to make them yourselves of buy 4 times Male to male stereo 3.5mm plug - cables.
No, I'm not talking about adding them to a receiver. I'm saying the the receiver has a RCA input for the Sub, my Megaworks doesn't. On mine, after you connect them via RCA, the Sub has nothing to connect to:(
You connect 3 stereo 1/8"/3.5MM to Male RCA from the computer to this Sub and it then acts like a Passive Sub. The sub then picks up a LFE that sent through the the other 4 or 6 (not counting the center) speakers. You can do this with a Receiver by connecting the Sub between the fronts for example.
I'm saying you can use this from his Motherboard as he's asking. There are 4 connectors (outs) on the I/O Panel from the Mobo's Sound System and these are;
1. Front L/R, One Stereo Mini Plug to RCA
2. Side L/R, One stereo mini Plug to RCA
3. Front Center & Sub One Stereo RCA
4. Rear Center For 6.1 and Two monos for 7.1 One Stereo. For 6.1 use a Y splitter with two female to one RCA. 5.1 is easier.
Creative Speakers and sound cards.
For 6 and 7.1 things change. While everyone in the market uses these 4 Speaker outs Creative uses 3 and Matches their speakers discrete in and outputs. Creative uses a Combo out for the #3 output. They use the same 3 above but also adds another Pin making it 4 on the Orange one instead of 3 pins. THAT PIN is for both the Rear Center for 6.1 and or Two Monos for 7.1. So #3 changes to Center, Sub, Center and Ground.
To use this as it was meant, You'd need a Female 4 pin connection to 3 RCAs and or a splitter for 7.1's two from the motherboard's sound system's four. If you just use 4 Stereo jacks to the Creative Speakers, you end up with something like using a Passive Sub on a Receiver for example.
Find a Cheap 7.1 X-Fi on EBay or the Creative EBay Store. I Ditched the Computer Speakers and went with a Receiver and never looked back.
Thanks guys, for trying to help. I'm sorry to say that I'm still not sure what to do. It sounds like if I could buy the CL cable, I would be fine. XP is setup for 7.1. I used these speakers with my old mb and a CL sound card with no issues. I wanted to use the onboard sound in place of the CL with my new mb, Asus Striker Extreme.
I don't have RCA jacks, except for the actual speaker connections. I have 4 mini stereo jacks on the back of my sub and 4 mini stereo jacks on my onboard sound card. I understand that the orange cable is the one causing me issues due to it not being a normal cable. That said, I'm still not sure how to make this simple cable connection work, in 7.1 I get sound, but not 7.1, again XP is configured correctly. This is a cable issue for sure. I wish I could just buy the right cable and connect it, and be done. I'm not clear as to how or why I need to make a cable. Radio Shack does not sell any other mini stereo cable, other than regular one. The camcorder cable won't work, as that has RCA jacks, again I don't have RCA jacks for my sound connections, only the speakers.
I'd like one person that has the same S750 7.1 speakers and a non-CL sound card to tell me exactly what cables were used and where to buy them. And, that it is running in 7.1.
What a joke this is for simply connecting speakers. If I can't this working, I will never by CL again. Logitech and other speakers use the standard type of connections that work on almost everyone onboard mb sound, or any other non-CL sound card. Why CL had to make this so hard is beyond me.
If you need pictures or anything of my setup, let me know. The PDF for my system shows the connections on page 9, but only lists CL sound cards, of course.
Thanks again for all of you trying to help clear this up for me, but I must say I still need help.
Thanks,
Thanks,
Steve
Sorry I couldn't help you more:(
The onboard sound is not that good but that's not the point. If you'd be happy with just mobo sounds, you might as well look at a X-Fi Xtreme Audio that's VERY cut rate version and is only X-Fi by name and driver.
http://www.computerbrain.com/applications/search/itemdetails.asp?sku=SB0792VP&sc=FRG
I'd use it over Mobo sound.
Thanks,
Steve
Here's how I can connect them with the onboard sound, i know it's the CL cable but as I told you, it has nothing special, just 4 stereo cables attached.
TO: HSE
It's not like mine. It doesn't feature 4 cables, just 3. Even the RCA inputs are just 6 and no Sub connection. Dam my bad!
This makes me sad. Is Creative on the verge of releasing something new or are they going to sit on this x-fi for awhile. It so pisses me off that I hvae one side working and not the other. :mad:
The PCI-E X-Fi 2 is next up but Vista sent it back to the drawing board is the rumor, who really knows what the facts are:confused:
Its unfortunate, because this definitely caught my eye: http://www.newegg.com/Product/Product.aspx?Item=N82E16829127002
and its also unfortunate that m-audio apparently has fallen off the map with shit support, i had high hopes for them...
That's the one I have planned for my HTPC. The Audigy 4 in that rig just doesn't cut it and I want DTS Connect for Movies and etc..,.... Yet, I wouldn't dare use one or any of those (CMedia based) for my Gaming rig;)
I just re-read through the help you tried to provide but I might be having a senior moment...
The suggestion was to find the 4v4 plug to replace the 4v3 one but why would that work when removing the gray plug from the sub and running a bypass would not?
Again, there's NO WAY to connect 4 cables to the sound card be cause the SOUND card has only 3 outs, not 4 like most other cards. I got so caught up in the card I forgot he was talking about built-in that has 4 outs. The speakers ship with; 1. Generic 4 stereo Cables and 2. Creative's own 3 (2 stereo and 1 Tri-Out) cables for their sound cards. All anyone has to do is look at the THX console Speaker Connection. Now if you don't have it installed, this will be missed. I said "my bad" because the guy was talking about Mobo's Generic 4 stereo outs and the Gigaworks can support this. Megaworks are 6.1 and DON'T.
The sub is not Bypassed at all if you use the 6 RCA's, the Sub will pick up the LFE channel that all sound sources send out. Many times these are sent Multiple ways to make sure the sub is fed. For my Megaworks, I'd have to use a Y splitter for 7.1 since there is only one
Example, my Pioneer VSX-D711 sends a LFE to the rear via L+ and R-, hit's pretty hard too! Same one the front channel. I never claimed to perfect, make mistakes and but try to learn from them. If I'm wrong, hey!
That's an interesting twist, running the 3-4 cable and an additional stereo cable for the side channels. Give it a try, according to some measurements I did when you connect the 4-pole miniplug to a normal stereo miniplug, the extra pole is grounded. The side channels are the extra pole, so if you connect the cable, leave out the gray plug and run another stereo cable from gray to gray it *might* work.
My onboard does have 4 outs. The issue is getting all 7.1 channels from my onboard as opposed to buying another crappy Soundblaster card...
And here's the problem. I ran the bypass from the gray but I only get ONE side channel, the other does not function :(
I now think you all understand how jacked this issue really is. The bottom line is you cannot just buy regular stereo cables from RS and make it work in 7.1 with the mobo sound. If CL would simply make their 4x4 cable available here in the US as they did in EU, then all of these issues would go away. The only other solution is to toss the speakers in the trash or buy another CL card. I won't buy CL anymore due to this proprietary crap! Any other decent speaker system would simply connect right to any normal mobo sound. Never again!
I just bought the cheapest CL xfi card and everything is working again. I would have rather just bought a dam cable from them, which is why they most likely don't sell it here...they want us to keep buying the CL crap.
My speakers are good, so I couldn't justify selling them or buying new ones.
Good luck to all who will still try to resolve this. :)
Steve
thats exactly what i did with my p7800 7.1 setup. i bought it a week ago, saw that creative in their ultimate wisdom didnt include a standard 4x4 cable to use with other cards(although they showed a picture of one in the instructions) so i unplugged the grey one from the sub, used a male to male patch cable from the side out on the mobo to the side in on the sub and everything works great for me.
If the cards where crappy, I wouldn't use them=P IMHO, using anything for gaming that's NOT a an X-Fi or Audigy 2 is crappy LOL! Your problem is self made and all in your head. Onboard is CRAP and I'd never use it over even an old Creative or many of the CMedia Card geeeesshh!
In fact, same goes for the Gigaworks Speakers when a nicer Receiver and *REAL speakers would do a much better Job. NOTHING can make shitacular Onboard sound worth a damned. Just in case you missed what I said, onboard SUCKS IMO.
