Creating seamless display (dual monitors)
B!nd.
I am having trouble lining up my 3840x1080 wallpaper on my dual 24inch 1080p monitors.
I can't find a way to may it so that the wallpaper on the right lines up perfectly with the one on the left. Currently the right wallpaper is hanging above the left one. I can't find the right option in the nvidia control panel :mad:
Thanks, but I was hoping to do it without any 3rd party software (with an exception to nvidia control panel)
Can you post a picture?
If the picture is exactly 3840x1080, and you have your monitors lined up exactly horizontally, then using the "tile" layout of your desktop background will make your background strech across both.
I think the OP is looking for some form of bezel correction for the desktop wallpaper...I'm guessing. But yea pics are needed.
I'm not sure if it is a bezel correction or not. I am not really familiar with this.
But I have a 3840x1080 wallpaper that I set to "tile." I can post a good example when I get home but it's NSFW hah...its just a really good example.
Thanks guys.
Right click your desktop and choose screen resolution. Make sure both your screens are lined up there.
What is the width of your bezel?
I can fix this is You link to original pict, or upload it somewhere that's not photobucket.
Also, what size are those monitors?
