I need to print my own circuit, but I don't think the usual PCB etching technique is what I want - I need to print onto plastic (like an overhead transparency.)
The reason is that I'm trying to convert a straight rectangular keyboard into an ergonomic one by adding a bend in the middle. I had at first tried to join the two halves of the plastic circuit inside the keyboard with plastic and paint in the conductive traces with conductive material and masking, but I could not get the precision that I'd need to successfully pull this off. Therefore, I think it could be best if I could somehow scan the halves of the circuit into Photoshop or the GIMP, draw in the new traces, and print them out onto overhead transparencies.
I'd probably be able to fit each half onto a standard sized transparency, so I wouldn't need specialized printing equipment. The only thing I'm not sure of how to do would be to modify the ink or ink cartridge so that it uses conductive material in place of the ink.
Is anything like this even remotely possible? It would vastly facilitate this project.
I'm also looking for some super-glue-like substance that has conductive characteristics, so if anyone has any suggestions for that, I'd be happy to hear them.
