So with the death of WinXP, I am going to be embarking on a quest to install 33 new PCs and recondition another 20 at the speed of lightning. I want to take one of the new PCs, install the apps that I want to install, then create an image to use on the other PCs so that I only do one actual install. Unfortunately, I don't know how to do this and I can't seem to find a good guide on the net. I had a smaller 16 PC deployment I did a few months back using an Acronis Live disk and did a partition clone which worked well enough but there were some oddities that still required at least 15-30 minutes of time spent with each machine. I'd like to be able to image them and they're ready to go. They're all Dell machines with Windows 8/8.1 Pro(I didn't order them so I don't know which exactly) who's Windows product keys are embedded in BIOS. The image would also contain an installation of Microsoft Office...if that matters any.
Also, if it can be done using Deployment services that would be awesome...though that's still a bit of a mystery as to how I would get an image created and then imported into WDS properly...
HELP my fellow [H]er's...HEEELLPPP
