I am having speed issues with over 1000 movies in a single folder when browsing through a DLNA app on my TV. Is there a simple script or application that will take my movies (all in individual folders) and create genre folders and put the movies into the appropriate folder?
I have used XBMC and scraped all the movies if that helps. I do not really use XBMC often since I use the DLNA service in my synology NAS to serve up movies to the smart(ish) TV.
Any help would be appreciate or you can just tell me I am silly.
