Create my own fan controller
mdawg
Alright the fans in my computer are crazy loud, and all the fan controllers you can buy will only take the voltage down to about 7v which with my fans I dont think will help because I want it to become not audible at night but still move a little to keep some air circulating. I was thinking using a resistor for this or something that will make the voltage drop to 3-4volts to the fans when I flip a switch. Your comments?
I think it would be alot easier to use this. It allows you to adjust voltage from 0-12v.
However, it is always cool to build your own stuff as well, that's what modding is all about.
