So I was watching a movie in mplayer, and the screensaver kicked in, so I moved the mouse and tried to get out of it, at which point that program froze up, so I decided to log out and try to fix the situation. At that point, it gave me a weird login screen I'd never seen before (it had a yellow flower if I recall correctly) and the whole thing rebooted.
I can get to GRUB, and I then when I choose linux options, it says CRC error - system halt, and if I try to boot winxp, the comp reboots.
Does this sound like a bad HDD, or something less sinister? I can't hear any grinding or whining sounds from the hdd, and it's only like 6 months old. Should I just reinstall and forget anything that was on the linux partitions? Are there any other constructive steps I should take?
Thanks
Thanks
