- Jun 11, 2003
It has gotten slowly worse over time. Monitor will click off and the rest of the PC will freeze after about 10 seconds. For example, if I am playing a game, on Skype, or doing anything with audio I can hear it going for about another ten seconds.
For some reason the computer did this twice while trying to post this.
I have adjusted my CPU overclock up, down, and back to stock.
I have increased voltage by a tiny bit and raised the power limit with clocks still stock.
Installed/reinstalled tons of driver versions.
At one point I actually COULD NOT install the driver. Every single time I attempted to install it the screen would black out as described above.
I cleaned all of the drivers on the system, booted into safe mode, remove all remnants of AMD video card drives, and then installed the driver only through device manager without the CCC profile.
My card is a reference Asus R9 290. I have actually had this problem since day one but it only happened once every couple of weeks and I thought it was something else causing the issue.
I currently have a brand new power supply hooked up just in case it is that. I have done a CPU/ram stress test in Linux and it works fine.
Its 3:30am where I live so I may just be rambling right now... but I am sure you get the point. In my googling this apparently might have something to do with the lower power mode of the video card.
Thoughts?
Thoughts?
