Crazy question...
If the monitor has vga connections, can you... seriously, attach a newer (lcd) monitor to a old pc?
I'm considering taking my tandy 1000 out from where it's been and putting a lcd monior on it... lol
It should work if the LCD supports CGA (600x200) or EGA (640x350) resolution. It will look like crap but that's to be expected.
It depends on the computer, some use different monitor connectors but as long as it matches you *should* be ok.
