I built this rig about 2 weeks ago.
Today I started running into some crashing issues, games were locking up and I got a couple bsod's.
So i started checking into things and noticed my pwm temps were looking alittle high.
So I fire up OCCT and watch the temps... and pwm hits 82C and then I BSOD!
My setup is:
Abit IP35-e
[email protected] 333x9 with a Big Typhoon
G.Skill DDR800
My system(37C while OCCT running), cpu, and gpu temps are all good. CPU stays under 60C. Everything is at stock volts
Well right now I set back to stock settings and am rerunning OCCT, but this board should easily do 300fsb... Not even 10 minutes in PWM is at 75C
I am thinking about RMAing it. I guess my other option is to mod it.. maybe put some as5 on the heatsinks, add a fan or something. My problem with that is I don't wanna do anything to void the warrenty because this is worrying me. Which heatsink on the mobo goes to the PWM? I'm not sure on this.
Question, does newegg allow you to return a part for cash back incase I decide to just get another mobo? Or is it just return for same part.
My setup is:
Abit IP35-e
G.Skill DDR800
