Crazy Over Heating (110C)
Kalden
A friend of mine has an Athlon64 system. He built it probably 2 years ago. A few months ago, his system started shutting down when he was doing too many things at once. He has just been living with the problem, but the other day, I looked into it and was completely shocked. His CPU temp was 110 degrees C. No, you didn't read that wrong. CELCIUS.
I had started up the computer, started a game of StarCraft (I know it's old as hell), and a few minutes in, the computer shut down. I started up and checked the temp in the BIOS to see 110.
It's just insane. I don't know how his computer still boots. I thought maybe the temperature sensor was busted, but if you let it sit for 20 minutes with a house fan blowing on the CPU, it reads out at 50C.
Does anyone have any suggestions? I know there is probably hundreds of possibilities, but maybe someone has had a similar experience. He is using the AMD stock heat sink/fan. We tried using a house fan to cool the cpu, but the problem didn't go away.
Thanks for any advice.
Take a can of compressed air and blow out any dust inside the heatsink and computer. The heatsink must be clogged with dust from over 2 years of use. If that doesn't work, get some Arctic silver 5 and reapply the thermal paste. If that doesn't work, get a new heatsink.
