Crazy motherboard? Please help...!
TeeJay
Hi,
I'll start from the beginning, my setup used to be this way:
ASUS Crosshair, AMD Athlon 64 62-FX 2.8 X2, XFX 7950 GTX2...
Anyway, I thought I'll upgrade, I bought a Phenom 9950 BE, 2 XFX GTS 250's, and installed them, when I tried starting the PC up, it gets stuck at the page where you can press something on your board to get into the BIOS, and it just stays there. An another restart, and the same result.
So I took it out and I've been told that the BIOS is dead for some reason, so I bought an another motherboard, and the same thing, the BIOS died.
So I took it out again and they told me that the processor has caused all this, so I replaced the processor, got myself a temporarily motherboard, since I have no money left, which is the ASUS M2N68-AM SE2(Socket AM2+) motherboard, which is a low end motherboard which I thought I'd use temporarily until I get myself some more money for a new motherboard.
So I installed everything, M2N68-AM SE2(Socket AM2+) motherboard, AMD Phenom 9950 BE, XFX GTS 250, OCZ 1GB RAM x 2, and when I tried starting up my PC, it said "This CPU is not supported by this motherboard" or something like that, then "Press F1 to continue", so I pressed F1, I got into my OS, within 5-10 seconds, PC restarts on it's own, I tried with it for a few times but it kept doing the same thing, then I switched back to my old CPU(Athlon), and it gave me the same thing...Then I thought I'll try to remove a RAM, and when I did that, everything worked fine, except for whenever I try to get into games, watch videos, or do such things, PC gets stuck and I'll have to restart.
EDIT: One more thing, can I install AM2+ CPU's on AM3 sockets?
Any ideas?
Thanks in advance
TJ
Have you tried updating your BIOS? If you're getting CPU compatibility errors (even though you probably shouldn't be), that could be the cause.
Also, you can't install AM2 or AM2+ CPUs on AM3 motherboards because they don't have DDR3 memory controllers, You can however install AM3 CPUs in and AM2+ motherboards.
Hi Zero, thanks for your reply
Umm, yes..I Have updated my BIOS to the latest version, and I still get the message that my CPU is not supported by this motherboard.
What's making me mad is the system is working fine, CPU is in a great condition, everything is stable, but when I try to play a movie on WMP, or RealPlayer or anything else from my system, pc just stucks up and will not work until I reboot, if I play a movie from Youtube or something it's fine...
TJ
AcBel ATX12V POWER 660, model: PC7016, that's all I can see on the sticker on the PSU...
I found the problem. It was my GFX's Drivers, when I removed them, video's are now playable and everything is fine, I'll try to re-install the drivers and see if the problem comes back.
EDIT: I have just re-installed the drivers, and the problem came back... :\
So, I'll try to install the drivers from the CD instead of getting the drivers from their site.
EDIT #2: I installed the older drivers from the drivers disk(182.42W), now video's are working, but whenever I run a game(CSS), I get a blue screen with [nv_disp] in the bottom of the blue screen then it restarts.
Any ideas? :(
TJ
Well, it could conceivably be a faulty video card in that case. Do you have another one you can try?
Okay so I installed my old 7950 GX2 back in, and everything's working fine now -.-...
Thanks a lot man, though...Do you know what might have caused my 250 to be faulty?
TJ
It could be any number of things. It might have even been faulty from the start. In any case, the cause of the problem doesn't really make a difference. Just RMA the thing and get yourself a working card :).
I can't lol, I didn't buy this from my country, I bought it from Malaysia which is 8 hours in plane from my country.
Anyway, I have used it before, it wasn't faulty from the beggining... :\
TJ
