Sounds like a VPU crash to me. Do you have auto-recovery enabled? (I didn't look to see if it was ATI and sigs don't show up when posting) It may not be working. But that's what mine did the 1-2 times I ran CSS video stress test when I had my 9150 OC'd a few Mhz too high.
many years ago, i was having odd crashes that i couldn't explain and tried everything and finally found out that it was the modem that was bad and causing the crashing.
it could be anything from another pci card or even the motherboard. maybe try removing the sound card and other cards and seeing if it happens. i'd probably turn on the onboard sound for the time as gaming for hours w/o sound isn't exactly fun
I am having the same issue as you, after a random amount of time running any 3D application the video cards fan powers down quickly followed by a "No signal" and the game or whatever sound is looping. Then I have to hit my restart button to get the screen back again. This is a very common issues with Oblivion, FEAR, and BF2142. I don't get it nearly as much with say, HL2.
I have run artifact scanners, and found nothing, same as you, I have run memtest and found nothing, my video card is a X850XT Sapphire, and my PSU is an Antec SmartPower 2.
Full specs:
CPU: AMD X2 3800+ 2.0GHZ. Not overclocked.
GPU: Sapphire Radeon X850XT. Not overclocked.
RAM: PQI Turbo 1x2 512MB. Not overclocked.
PSU: Antec SP 2 500 watt. Barely stressed.
MB: Biostar NFORCE4 Ultra.
HDD: SeaGate Barracuda 7200RPM 320GB SATA 3.0
PCI: Generic LAN card. Been using it for years, and has run fine in other computers, however what that guy mentioned about could help.
So I've been looking for anwsers to this problem too, I have found none, except other then returning my GPU and hoping that was the cause, just a faulty GPU. then again it could be the motherboard, this is just one of those issues that is so random, and so weird tha you can barely pin it down without swapping tons of parts out.
I had some issues like that before and was associated to my ram. I have it overclocked and when they would happen I would back it off a smidge and I was good. If anything at all is overclocked back it off a smidge and change your audiocard position if you can just for **its and giggles. Also check temps. Very important.
I have a radeon X1900XTX and Soundblaster X-Fi Xtreme music. I had the SAME exact problem as well, i'd be playing any game (usually Anarchy Online) then all of the sudden the sound would loop and the screen would go black. It did it for months but I dident bother to care enough to fix it (was watercooled, PC Power and Cooling 1kW supply). One day I reformatted... and its NEVER happen again. The only thing I did different is that I did not install all the weird applications for the soundcard. Just went to creative labs website and downloaded bare bones drivers. Its been working fine ever since.
BUT I took everything out and put it back together... I load up ati tool or even 3dmark06 for a couple minutes then boom, crashes... while looking at ati tool, even with the X1900xt's fan 100% and underclocked... NO artifacts shows in ati tool before the crash.. in speedfan, the voltage on the 12v rail goes from 11.90 to 11.84 and a few seconds later crashes.
So I'll toss in an OCZ Gamestream 600watt soon and we will go from there
Well I didnt buy the new PSU yet but I found a pattern...
I can start up the computer, run atitool for a couple minutes.. ( 2) then it crashes the computer. ( or any other program.. 3dmark06 etc etc. )
If I keep doing it, and rebooting everytime it crashes.... atitool keeps running longer... 6 minutes now over 20 minutes and everything is stable as a rock....
Sooo the more I warm up the computer, the longer it is stable and it will eventually be 100% stable and I can game all day long without a crash?
someone please please help me, I was going to get a new psu, but now since it works so good after I let it crash a few times I am having second thoughts about a new psu.
