im trying to clock an athlon jiuhb 1800+ tbred and im stuck at about 192fsb
for the most part its capable of going higher, ive got it to 230 before but i get weird shit going on in prime that i dont know what to make of:
if i set the cpu speed too high for the vcore i get the usual miscalculation errors coming up and it can be turned down and runs fine, this keeps going up and up and ive got it to 2.2ghz maybe 2.3ghz without it giving any miscalculations but when i get that high it keeps crashing and restarting, and when i check prime logs there havent been any errors before it crashes, temps are reasonable (thermalright 900a & panaflo L 92mm)
so i can turn it down a bit and when its in the sweet spot i get prime telling me:
Possible hardware failure, consult readme.txt file, restarting test.
ERROR: ILLEGAL SUMOUT
and after the set number of these the test stops... and the computer does dodgy shit like slowing down and not posting when you reset it once its been on for a while
the key thing seems to be when i play around with voltages, obviously with everything above i have been playing with the vcore but then if i also try vdd (chipset voltage which i need to get 200+ fsb) and vdimm (dont seem to need this, but still) the problem is far worse, i get the weird prime error and same problems but at lower speeds (or vcore)
so im guessing this has nothing to do with cpu instability, its just that something is lightweight and cant handle higher voltages going in... my hardware isnt great but surely i should be able to increase the vdimm by one step when everything else is at stock without it gaying up?
epox 8rda3+ rev1.1 (dodgy rev yes but it will go to 230fsb for a while so i dont think ive got a duff one)
crucial ddr400 cas2.5 (i get these problems at 200fsb or even lower when its set at 3-6-6-11 so i dont see how its the ram)
which leaves:
levicom 550xpe-p psu
which is a bitch because im sure hardly anyone will have heard of them on here, from what i can find out they are only properly shipped in germany and a few of them around the rest of europe... but i read a couple of reviews and it seemed to compare to a 550w antec they had with it... ive bought a new psu before when i didnt need it and just ended up selling it for half of what i paid bc it sounded like a jet engine so im hoping someone here will recognise the symptoms and tell me if its the mobo or psu so i dont end up on a spending spree
sorry for the length
DISCLAIMER: IF YOU HAVE NOTHING TO SAY EXCEPT "IVE NEVER HEARD OF THAT PSU IT MIGHT SUCK ASS" PLEASE REFRAIN FROM DOING SO AS I ALWAYS PRAY THAT PEOPLE WHO BUMP UP THEIR POST COUNT FOR THE SAKE OF IT ON MY THREADS ARE CASTRATED BY A GOD-GIVEN ACCIDENT... this does not apply to anyone who knows at least something even if it doesnt help
which leaves:
