Crap, what'd i do? (System not booting)
Pilky
So i was messing around a lil earlier tryin to over clock my system.
Anyways the last time i tried to up the settings, it loaded to BIOS, got to that next screen and that's it, black screen.:eek: :( (monitor still on)
Hope i didnt break anything, i pulled the battery and moved the cmos jumper to the left like the motherboard suggests and it still wont boot up.
Any help appreciatted.
(System in sig)
XP Pro SP2
I hope it's not the same thing that happened to mine but I could never get mine past that when I had your same problem, cleared the CMOS everything, just nothing would work, so I had to do a fresh install of windows.
Make sure you unplug your PSU as well when you're clearing it, and I hope you moved the CMOS jumper back to its original position. You're only supposed to jump the 1-2 pins for about 5 seconds
Well after trying everything, i had to do the same thing.... reformat and install windows again.
Better then frying hardware... this will teach me a lesson to jump into new hardware and start messin around. (this is a new build since a socket A)
