Crazylegs77
- Mar 2, 2010
Was getting annoyed by a new loud fan and had an old fan controller
so the thing is it uses a molex pass thru adapter with a small port for the fan dial to attach.
Hooked the adapter to the fan then the minute I touched the molex plug to the power supply I smelled burning so immediately shut down. Everything seems to be fine but was a bit unpleasant since it is a new system build.
what the hell do you think happened? bad pass thru connector?
