Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Keep getting a pop-up saying my Nvidia graphics is not getting enough power and is lowering performance to keep from being damaged. I have an Antec Smart Blue 350W. What's going on?
Athlon XP 3200+
512K RAM
Have you checked with a voltmeter to see if that molex is working? Have you tried a differen't molex? If the molex is working then you have a bad video card or powersupply.
huh? is the card working now?
download rivatuner. use the hardware monitor to see what the clock speeds are when you run a 3d app. might just be a buggy error message.
Well a 300 or 350 Watt is only enough if you don't have too much else in your system. If your molex connectors are plugged in you should really get a volt meter to check your voltages.
What all is in your system taking power? That's an important question really.
Try using a differnt molex plug....sometimes PSU's are tempermental about that kinda stuff....make sure it's directly coming off the PSU too (not from a splitter).
