Crackling/whirring noise from SSD?
mao58
My HP Pavilion laptop has a Intel 660p 512 GB SSD disk. I can ear a light crackling/whirring noise from the case when I'm scrolling down repeatedly a page or cells (e.g. Excel) when the laptop is running on AC. The noise become no more audible when the laptop is running on battery power. It's a mystery!
Kardonxt
Along Master shake's line of thinking - Are you sure it isn't the laptop's cooling fan ramping up slightly under the extra load of scrolling through a lot of data quickly?
pendragon1
if the noise has a pattern that seems to match up with on-screen content in an odd way, it's probably coil whine from the internal voltage regulators. If the noise is continuous and ramping, it's probably the fan.
i have numerous dell desktops at work that do this. with the side panel off you can hear it change with practically everything you do; browsing, youtube, clicking through explorer etc etc. totally possible that a laptop could do it.
NattyKathy
Yeah it's bizarre when it happens. Seen it on desktops and laptops but more noticeable on desktops, especially with a powerful dGPU and/or shitty VRMs/PSU.
michalrz
It's actually a common problem and can get really annoying when you take your laptop to show off some presentation and hook it up to a projector/sound system via VGA+analog audio.
It's not the SSD's fault per se, the laptop should be considered as a whole. A component in the voltage regulation section or LCD brightness circuitry can start singing along with some other inductive/capacitive load in the chain.
Sometimes getting another laptop charger helps and making sure all your stuff is plugged into one socket and that socket is wired correctly.
likeman
coil whine
if it's from speakers if your using a cheap PSU that hasn't isolated the AC from the DC can do this (run your finger across anything metal you feel a buzz from it)
pendragon1
coil whine
sounds like it but he is on a laptop, so not his choice on a "cheap psu(a/c adapter)" but HP's, probably 2 prong too.
Mizzer
coil whine
Interesting. I wonder: perhaps M.2 drives on desktop motherboards are better isolated and, therefore, do not suffer from coil whine.
pendragon1
could be and or it could be the board makes more coil whine so it drowns out the m.2 like the dells at my work...
likeman
never heard a m.2 SSD wine before normally the other components in the system that's doing it (usually it's the GPU )
likeman
i had cheap PSUs that make the trackpad go bonkers because the touchpad is referenced to ground due to the cheap ass laptop PSU isn't isolated correctly (real PSU was working fine just had to wait 2-3 days for a real one)
you can actually feel the buzzing on the trackpad sometimes or if you brush the tip of the 19v outer barrel DC plug you feel a buzz as well (make sure your not grounded when you do that as the cheap china PSU the AC isn't isolated so that's reference AC 120/240 your feeling sometimes)
pendragon1
Perhaps I’m deaf to it but I hear nothing from my desktop builds. I like them silent.
good quality parts have less of a chance but dells mobos power systems are basically bare minimum and are noisy as fuck!
ah. i was thinking desktop = psu, laptop = a/c adapter, technically both are the same thing...
Mizzer
That makes sense. i tend to build rigs with quality parts. I can't remember the last time I used a Dell pre-fab.
pendragon1
most self respecting [H] members wouldnt, but its what we have a tonne of at work. they are great for business use because of their support.
pendragon1
(business ones anyway)
thats the key, and im only talking about the mobos being noisy, they work fine. only issue we have had with dell stuff in the last year has been a dock that shipped with the wrong a/c adapter and one laptop this week had its board swapped twice, on monday and then today. oh and now long wait times for new units. now ill stop with the dell stuff dragin the thread ot...
NattyKathy
coil whine
grounding/isolation issues are fun. A place I used live had a wiring problem (measured 16v from circuit earth to concrete floor, 55v from live to circuit earth, and 55v from neutral to circuit earth, in case anyone feels like deducing wtf was going on, I still have only a vague idea) and when I'd run my hand across laptops with mag or al chassis I could feel strong 60hz coupling. Mains is weird.
mao58
I never would have thought an SSD would make noise. Read this and give it a try if your HP has this option:
https://www.dell.com/support/kbdoc/...y-laptop-makes-a-strange-squeal-buzzing-noise
The laptop doesn't emit an audible squeal when the system is idle or under light use, when I'm scrolling down repeatedly a page or cells (e.g. Excel) or when I run a disk scan (like Intel SSD Optimizer). The strangest thing is that the noise becomes almost no more audible when the laptop is running on battery power.
NattyKathy
the change when it's running on battery could be a clue that its either something in the DC-DC converters on the DC-in side that are singing, or the harmonics in the ripple from the external supply are causing transients in other DC-DC converters to be amplified.
