I am going to be building a new computer (new here, first build. I have learned a lot, but still have much to learn). Still sorting issues so have not drawn up a complete build list as stickied...that will be coming though
. The primary use mostly be Adobe LR3 with some PSCS5 for whatever LR can't handle (which at this point seems less and less). I do shoot with the Canon 7D so although video is not really my thing, I may dabble with it some time soon. Anything I do will mostly likely end up being Web quality though. To a small extent I also use Dreamweaver, and may start using Adobe Flash Catalyst to work on some small Website projects.
I understand that in 2011 some of the Sockets will be changing and backwards compatability is questionable (thus likely any upgrade in the future will be CPU and mobo both required). I was led to a benchmark where generally the i7- 860 slightly outperformed or equaled the 920 (except some of the 3D rendering) http://www.anandtech.com/bench/Product/47?vs=108. It seemed to be particularly better in the single threaded catagory and that is apparently where LR does a lot of it's work http://www.foto-biz.com/Lightroom/Cpu-for-lightroom3. The two units are essentially the same price, but with the 860 the mobo would be a little cheaper.
So, am I getting slightly better performance and saving a little cash or am I just missing something?
Mods - this should probably be in the Intel CPU area. Can it be moved to the proper forum?
