Jarod888
- Dec 19, 2005
I just received my latest issue from CPU. They had an interesting article on soft modding your 8800 GTS into a Quadro FX 5600. Basically for those of you that don't get CPU they use GPUZ to verify that you are running a "moddable" GTS. ( Special Thanks to CPU Magazine for the Info.)
There is a file in the Quadro Drivers called nv_disp.inf Near the bottom there is a group of text called "Localized Strings" which lists all the graphics cards supported by the driver.
The line that is important is "NVIDIA_G80.DEV_019D.1 = 'NVIDIA Quadro FX 5600." That basically means that a G-80 based Nvidia Card with a Device ID of 019D.1 equals a FX 5600. The D.1 is not important.
The key number is the Device id. In the article they site the last four numbers of 0193, which just happens to be what I have.
After that you download or open Rivatuner
On the MAIN tab under Target Adapter, click the arrow icon under customize.
On the customize menu, the first icon is a graphics card, or Low Level System Settings.
After you open up the Low Level System Settings click the NVStrap tab; (if it is not available you are not able to softmod your card.)
Click the Install tab at the bottom which will allow you to make changes. (All my tabs were grayed out until I hit the install tab.)
The middle section is called "PCI Device ID Settings"
Click the drop down menu at the upper right called Graphics Adapter Identification
Select Custom
Scroll through the list and choose Quadro FX 5600
Click Apply, restart your system.
After your system restarts you will have to install the drivers for the Quadro 5600 and restart your system again.
You can also reverse this by uninstalling the quadro drivers and using rivatuner to change the PCI Device ID Settings back to "Determined by Hardware", rebooting and reinstalling the correct drivers for your 8800 gts.
I don't really play all that many games, and I don't do a lot with cad, however I figured I would try this out. I am curious now to see if using the Quadro Driver, if you can use SLI and have multiple monitors?
This is just more of an information post, but please feel free to discuss. Also please post if you try the mod.
Thanks
Select Custom
Thanks
