CPUID? Confused!!
Percy
Hey all, I am confused as to what each one of these is telling me.
In the first CPUID It's telling me what is in each memory slot with the size, manufacturer, etc. Below that it is showing me what? What different profiles i can run the memory? or what each memory module is running at? if so that isn't right, right?
And in the second CPUID it is showing me what its showing DRAM Frequency 798.2 MHz. I'm so confused. Could someone please explain? i can't seem to figure it out through google.
The bottom half shows the timing settings that the RAM supports - there are difference profiles for different speeds, and you can see where it supports tighter timings at the lower speeds. You can check what the other modules support (they will be the same for matched sets of RAM) by clicking the drop-down box that says Slot #1 and selecting the other slots.
The second shot shows that your RAM is currently running at 800MHz (basically, allowing for the clock error), which is 1600 effective for DDR3. So it is running what it should be running.
