- Apr 13, 2000
Well in the BIOS I have overclocked my Q6600 a little bit, from 1066 to 1200 FSB and my RAM from 667 to 820MHz. I believe these are unlinked. Using my Asus P5ne board, and CPU-Z, it only reports stock settings for my CPU speeds. However not the RAM. Why is this? If I use Nvidia tuner to manually adjust my clock speeds, performance gets worse even if matched with BIOS settings, yet the new speeds will show up in CPU-z. Whats going on?
System properties lists 2.7GHz and CPU-z is 2.4GHz.
