cpu-z errors?
bkrawk
using w7, i7 920, and e758 board
when i disabled HT from my stable 3.6ghz overclock, my cpu-z and realtemp does not load, i also get 'error during driver initialization' with evga e-leet..what's going on? other things like superpi, IBT, and prime95 load fine..help me please, i've tried to reset bios and only change the ram timings and i'm still getting this problem along with this in the cpu-z error log:
bInitDriver(C:\Users\Andrew\AppData\Local\Temp\, 1)
GetCurrentDirectory = D:\Program installations\CPU
GetModuleFileName = D:\Program installations\CPU\cpuz64.exe
m_iOSVersion = 2 (6.1)
m_bIsAMD64 = 0
m_hDriverMutex = BC
m_szPath_2 = C:\Users\Andrew\AppData\Local\Temp\\cpuz132\
m_szFilename = cpuz132_x64.sys
bOpenDevice
bOpenDevice : WaitForSingleObject error = 258
vCloseDevice release mutex = 0
bInitDriver returned 258
CloseHandle(mutex) = 1
ive had this happen before on other machines as well as my core i7 system. they never stayed though, so im not sure what caused it.
it all started when i turned ht off while i was clocked at 3.6ghz..reset cmos, and i still got it.
looks like it went away though, back at stock speeds
Good to hear that it's all working out for you man :)
I have yet to incur a cpu-z error, and that makes me happy but like I said, glad you got through yours :p
I would still like to know what caused it though, can't find any information about it on the interwebs..maybe it was just a windows 7 rc1 thing
There is a new version that recently came out that installs. Said it improves launching and such. I still downloaded the portable x64 version.
the thing is that it wasn't just cpu-z, realtemp and evga e-leet also had problems loading
