CPU Won't Overclock
Discussion in 'Overclocking & Cooling' started by Champ, Dec 12, 2016.
  1. Champ
    Champ Gawd
    710
    Mar 22, 2006
    I've been trying to overclock one of my old CPUs (2500K) and it will not go through.
    I use the same guide when I used the 2500K religiously (http://www.tomshardware.com/forum/265056-29-2600k-2500k-overclocking-guide) to do so, but when I login and check CPU-Z, HWMonitor, or any related software, it says I'm running at the standard (stock) 3.3ghz.
    I would like to note I spilled a little water on top of my computer case a long time ago. Only thing I've noticed the computer having an issue (after drying and reinstalling components) was that the computer will not shut off until I force it by holding the power button. It will go to a dark screen, but the computer won't turn off. That's the only issue I have had.
    It is likely that is the cause of the CPU not overclocking, but just wanted to make sure. Every other feature works on the motherboard from what I know.
    Any ideas? Or is it because of the slight water damage?
  2. auntjemima
    auntjemima 2[H]4U
    3,241
    Mar 1, 2014
    I wouldn't think that would cause your issue. That said, after you restart the computer is the system still overclocked in the BIOS? Just getting a base for ideas.
  3. Champ
    Champ Gawd
    710
    Mar 22, 2006
    It is still overclocked in BIOS (or the settings are unchanged).
    When I use software to overclock the CPU, CPU-Z shows that is overclocked. I do not want to rely on a software OC.
  4. AlphaFox
    AlphaFox Limp Gawd
    258
    Jul 26, 2016
    if speed step is on it throttles the CPU down when theres no load, maybe thats what your seeing.
  5. Champ
    Champ Gawd
    710
    Mar 22, 2006
    Whether it is enabled or disabled it is still the same. :/
  6. Champ
    Champ Gawd
    710
    Mar 22, 2006
    Just noticed that no BIOS settings save right now. If I disable speedstep, speedstep is still enabled. When I enter BIOS, the values are still the same (as changed), but doesn't take effect.
    I.E- BIOS says 43. 43x100=4.3ghz, but when I enter desktop it says I didn't OC at all. When I disable speedstep in BIOS, it doesn't take in effect when I login and speedstep is still enabled even though I log back into BIOS and it is still disabled
  7. mda
    mda [H]ard|Gawd
    1,143
    Mar 23, 2011
    No BIOS settings are saved?
    Try the ff:
    1. Load BIOS defaults
    2. Use CMOS jumper to clear BIOS
    3. Reflash BIOS then clear BIOS
  8. Champ
    Champ Gawd
    710
    Mar 22, 2006
    I just did all 3 earlier ago and it seems to work now. (OC is active)
    I disabled Speedstep, but it is still power-saving (down-clocking) according to CPU-z, but I'll fiddle with it and see how it goes.
    Thanks!
  9. Furious_Styles
    Furious_Styles Gawd
    665
    Jan 16, 2013
    Did it fix your shutdown issue?
  10. spaceman
    spaceman [H]ardForum Junkie
    14,399
    Jan 7, 2005
    Mine is stuck at 3.7. Just weird. I guess I will just limp along a bit longer.
  11. Peter2k
    Peter2k Limp Gawd
    276
    Apr 25, 2016
    You remembered to set the power plan in windows to max power, and not balanced as that is standard?
    I can watch the difference in CPU-Z when I switch between the 2
