CPU won't go over 269
  • Thread starter Deleted member 143938
  • Start date
D
Guest
Rig in the sig
I'm following eclipses guide and trying to find the max FSB of my CPU, I set the settings at HTT:2.5 CPU:12 FSB:210, CPU (tried 200 first) volt:1.55 ram:1/2 (100), with that setting it didn't go over 225, then I changed the CPU mult to 10 and got to 269, but still seems very low, with my setup I think I should be able to do 300+ easy. I have a big typhoon on and CPU load never goes above 38-43 (depending on OC) during load.. anything I can try to do?
I by no means do OCing, but I know the basics. Have you tried lowering your multiplier on the CPU to like 7? I would try that and then up the FSB by one each time to see how far you can go. If then you can still get it to boot, try increasing your multiplier.
Wouldn't I be able to set it to like 1 then and set my MHz to 2400-2800 (if my mobo let me go that high) then :p?
Ohhh I think I got it, for finding the max CPU speed, I'm looking for the total Mhz.. like 2800, NOT what the FSB is in clockgen, but the total MHz, and modify it according to customized mutilpliers!
