DFI Daishi
- Feb 14, 2005
this is just a thought, and i'm only putting it up to try and get some of the current discussion on waterblock testing into a dedicated thread.
has anyone considered how accurate a measure of a waterblock's perfirmance with a "live" CPU that uses an IHS it would be to pop off the IHS, cut a small notch in a corner of it, attach a calibrated thermal probe to an edge of the CPU die, and re-install the IHS, passing the lead for the thermal probe through the notch?
i realize that poping the IHS off and then re-installing it disrupts the factory installed TIM on the inside of the spreader, however maybe if AMD was willing to release some information on the nature of the stock TIM we could mimic the original material when re-installing the IHS.
this is so simplistic that i suspect that it has already been tried, and abandoned for one reason or another.
mainly, can this be a thread purely about waterblock testing, and can we get input from all quarters regarding thoughts as to how it should be done?
