cpu voltage for a 960?
samsung
i want to overclock my i7 920 to a i7 960 specs. what is the cpu voltage for a 960?
Hmm, so many ways to go with this one. Have you overclocked a processor before?
The 960's voltage will have nothing to do with getting your 920 to 960 speeds. It is likely that you can hit 960 speeds with your voltage set to auto.
the voltage means nothing because no 2 processors overclock the same. especially since a 960 is a higher binned chip which usually allows for lower voltages at a higher clock then the 920.
what settings in bios should i change to oc my 920 to 960 speed?
