"CPU unworkable or has been changed"
JamesL
Abit ip35-e, Crucial Ballisix Tracer ddr2-800, and a used e6750 -
Ram leds are blinking, fans are running, gpu fan and hard-drive is spinning.
I get to the boot screen - bold letters with "Abit" ...
"click tab to get to post screen, or press shift to get to setup.."
Automatically goes to post screen...
Default CPU shows up as 2.0ghz, 333 x 6 (e6750 = 8x multiplier)
And it shows Processor name as Intel Core 2 Duo e6750 2.66gHz or something of that sort.
Memory shows as ddr2-800mhz
this error message shows...
"CPU is unworkable or has been changed. Please recheck - CPU SOFT MENU"
It says press f1 to continue, or delete to go to setup..
If I click either one, the tv continues to a blank screen - "Unusable signal"
I've already reset the cmos, and same thing.
What can I do? - Is it the cpu? The motherboard? Maybe it's the tv, that can't support the resolution of the bios screen(My monitor comes in monday) -
thanks in advance for help..
