flippityflap
- Mar 10, 2004
I have the p4 2.6C and a Zalman CNPS7000-AlCu using arctic silver 5, but I'm getting CPU temps of 53 now as the weather warms up a bit. Did I just not apply the thermal compound very well? CPU Database had people overclocking this chip with that cooler, but this is way too hot at even stock speeds. Should I wipe it off and try remounting? If so, what would probably be the safest and best way to remove the existing Arctic Silver?
Case temp is usually around 38 using a Lian Li PC-6070, which is fine with me. Before the weather got warm, the CPU was ~47 which was high, but not enough to really bother me. I don't like it in the 50s at idle for the obvious reason of it being excessively hot and not actually doing much. Thank you for any advice.
