CPU to Hot?
goldenfrog
I just upgraded to a P4 945D 3.4G setup. This is my first P4, my last Intel chip was a P3, and I'm not sure how hot it should run. I have it mildly oc'd to 3.7g. The screenie shows the temp while encoding one video, ripping a dvd and downloading stuff. Is that temp to high when the both cores are working that hard?
61c at 85% load isnt bad, those cpu's still run a bit hot and id say if it doesnt get much higher than that your just fine.
