spaceman789
- Dec 6, 2006
Hi im running an e6600 on an asus p5wdg2 ws pro and i have a zalman 7700 cooler and i used artic silver 5.
The idle temperature on my cpu is between 39c-40c and the motherboard is at 28C. I dont have the little switch, used to raise the rpm, installed for my zalman 7700 and mayeb i should use it?
I havent checked my temperature at load cause i still havent installed the OS , i check this temperatures in the bios, maybe the bios is reporting them to high?
The guy that install the cpu for me sayd this temperatures are in the average.
what you guys think?
