Well, I have searched for solutions to my problem but still have yet to solve it. I have googled it and also checked through these forums. I have tried the solutions that I have found but my cpu is still overheating and has reached 120 deg Celsius.
My pc specs are as follows:
Lian Li PC 65B 4 Fans 80mm Coolermaster
EPOX 4PDA2+ rev.2
P4 3.0 ghz Northwood (Stock)
Zalman CNPS7000B-AlCu w/ AS 5
2 GB Corsair XMS PC 3200
Seagate 120 GB sata / Seagate 120 GB IDE
Plextor 712 CD/Dvd
PNY GeForce 6800 GT 256 MB
Soundblaster Audigy
Thermaltake 480 PSU
Going to give a brief history of what changes I have made so maybe someone can catch where I went wrong.
I built my rig about 1 year ago or so with pretty much the same specs listed above except that I only had 1 GB of Ram. This is my first build and it went pretty smoothly.
Idle: 35-40 C
Load: 50-55 C
Ambient: 33 C
About 8 months later, my temperatures began to change a bit to the following:
Idle: 41-46 C
Load: 60-70 C
Ambient 33 C
I reseat my Zalman and there is no change in the temps. I decide to clean up the inside the case more to increase airflow. So instead of sleeving the PSU myself, I buy a Antec Neopower Modular PSU 480. I also purchase an XP-90c and a Panaflow 92mm fan hoping that these changes will bring my temps back down. However, temps did not change.
About 2 months after, I purchased another GB of Corsair Ram (same sticks). A few days after I noticed my temps were:
Idle: 50-55 C
Load: 65-95 C
Ambient: 32 C
So now I am like what the hell is going on. I try now more to increase airflow and use a dremel to pave a way for the PS wires to go behind the motherboard. I also decide to lap the XP-90c. So not only is my case very neat inside but now I can see my face on my heat sink. However still no luck. My temps stayed high.
Now present day, I switched from the XP-90c back to my Zalman and back to my Thermaltake PSU. And within approximately a 2 month period, my temps are now:
Idle: 95-100 C
Load: 100-120 C
Ambient: 28 C
I have used Speedfan and MBM5. I have reseated heatsinks quite a bit to see if I did anything wrong. I do the ½ bb at the center of the cpu method when applying the AS 5. I have pc dusted the inside ensuring that the inside is dust free. I havent felt the heatsink as of late but I have recalled it being warm to the touch. I am running on stock voltages and have never attempted to OC.
Is there something wrong with my Mobo? Cpu? etc? Did I do something wrong? Are my temps accurate? Should I stop using/gaming with my rig while my temps are this high?
If anyone can provide any suggestions, please feel free. Also if I left anything out please feel free to ask any questions. Thanks to anyone in advance that can provide any solutions.
- Blazeops
EPOX 4PDA2+ rev.2
Plextor 712 CD/Dvd
Soundblaster Audigy
Thermaltake 480 PSU
Idle: 35-40 C
Load: 50-55 C
Ambient: 33 C
Idle: 41-46 C
Load: 60-70 C
Ambient 33 C
Idle: 50-55 C
Load: 65-95 C
Ambient: 32 C
Idle: 95-100 C
Load: 100-120 C
Ambient: 28 C
- Blazeops
