Aug 26, 2004 #1 J Jesse80 n00b Joined Jun 4, 2004 Messages 4 I was just wondering what a good temp for a 2.8c intel processor is this is with stock cooling I believe mine gets up to 60c not sure if that is to hot thanks
Aug 26, 2004 #2 C CentronMe 2[H]4U Joined Apr 3, 2002 Messages 2,346 Is that idle or at load? For an at load temp that is fine.
Aug 26, 2004 #3 M M3ltd0Vvn Limp Gawd Joined Apr 7, 2003 Messages 373 3.0c w/OEM copper HSF w/factory thermal tape. Built January with plenty of burn in: 33c/91F - 35c/95F IDLE 49c/120F - 51c/124F LOAD Case temp stays between 26c to 30c. I use the BIOS, Intel Active Monitor, and AIDA32 for temperature information. Hope that helps.
Aug 26, 2004 #4 J Jesse80 n00b Joined Jun 4, 2004 Messages 4 that would be load it's just my case is has a sensor on the cpu and the alarm was set at 60c when I got it so I guess I just need to set it a bit higher
