Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
My barton 2800+ with amd fan is running at 52-58 Degrees Celsius on a Asus A7N8X-E deluxe mobo, I don't believe this should be the normal temp, im using Artic Silver TG on the processor. Any input on this would be much appreciated...
That is quite high, most overclock temps shouldn't be much higher than that, so you are running a little hot. Are you sure you've got the the Arctic silver spread correctly? Also make sure your heatsink fan is running at the correct RPM.
