I have an Asus P5E-VM HDMI, E6550 running at 433x7 (3.0GHz, up from the stock 2.33), Vcore 1.17V, and the stock Intel cooler.
I've been monitoring the stock CPU temperature from 3 different programs, and they are all different! All temps below were recorded just now at idle <2% load, with SpeedStep running the CPU at 2600MHz (433x6).
Rivatuner (with the Core2Duo plugin) says my temps are 17/21 degrees for core1/core2;
Core Temp 0.96 says my temps are 33/37 deg;
PCProbe (Asus Utility) gives one reading, 23 deg.
My question is, which program is the most reliable?
I have yet to check the temp reading in the BIOS to see if any of these temps correlate....I'll do that now. Anyone have any thoughts?
