CPU temp on full load how to detect?
I currently have my barton 2500+ overclocked to 3000+ (2.10GHZ) but I'm thinking of overclocking it at 3200+ speeds but I dont want to burn the CPU so I want to know if there is a program that tells my CPU temp on full load
thanks in advance
Yes, you can use MBM5, speedfan, and simialr applications, sometimes the mainboard manufacturer will include this type of utility with your install CD.
Later
MD
no he didn't, he asked for a program that would give temperature at full load. task manager cannot do that. it must be used in conjuction with mbm5. then he will know whats his temps are at different cpu loads.
Sc0rched said:
I believe he did...
