Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I was only able to find SpeedFan in the search and the only temps it read was my HD temps. So what's a good program for me to read my cpu temps. Specs below.
What motherboard do you have? I use Speedfan or Everest but have also owned motherboards that they dont work on. Some motherboard manufacturers also make their own program.
Everest is the newer version of Aida32. i've tried Everest and found out you need to purchase the product in order to get the temperature monitor. i am not sure how much better (if at all) Everest is to Aida32. i just have no information to back that up.
but Aida32 will have the ability to show you temps.
