CPU temp hits around 63C when I run Prime95
Super Mario
I have my Pentium 4 3.0GHz Northwood CPU overclocked to 3.75GHz. I have ran Prime 95 before and it ran without any errors and was perfectly stable. The temperature usually idles around 49C and when under load, around 56C. Now, I have notcied that it seems to get around 63-64C when under load. I ran Prime95 all last night, and when I woke up in the morning, I notcied the execution halted with an error. The system didn't carsh though. It does seem that 63-64C is around the quite warm side, but is it too hot that you will liekly ruin into problems? If so, is it an actual dnager to dasmaging my COU, or just shortening the life span if it runs at that hot of temps all the time??
Also, what is the PWM temperature? I have an ABIT IC7-G motherboard and there is something listed as the PWM temperature. It is usually around 51C at idle, but when the system is under load, it is 59C.
The system temperature is around 28C at idle, and around 35C under load. What is the system temperature?? Is it the temperature of the Northbridge chipset, or the ambient temperature inside the whole case??
Last but not least, is it possible I could have done some permanent damage to my CPU, but I don't know about it yet. Or would I have to leave my system on for too long once the CPU overheated enough so the OS would crash in order to permanently damage the CPU?? I am planning to get more cooling, but I ask this question just to make sure I can be relived that I didn't permanelt damage my CPU.
Abit IC7 series was known for reporting temps about 10 to 15+ higher then actual.
