CPU Temp Accuracy?
Phas3Zer0
Just wondering what the most accurate app to use is right now. Some software is showing different temps than others so I’m not sure which to go by. Whichever is closest to the hardware monitor in the bios? Here is my setup.
CPU - AMD Phenom II X6 1090T
Motherboard - Asus M4A88TD-V Series
Current Software Temperature Readings
ASUS AI SUITE 30C
PC PROBE II 30C
AMD OVERDRIVE 21.6C
CORE TEMP 21C
EVEREST 22C
SPEEDFAN 30C
I use a combination of 3.
cpu temp
cpu-z
tm monitor.
if they all are different i go with the average for them. but they are usually within a few degrees of each other.
