CPU swap question ....
I have a old box that friend gave me and it has a MSI mobo model ms-7021 with a KT600 VIA chipset and a Athlon XP proc. According to CPU-Z, its a Socket A Barton core that runs at 1.1 gigs.
I was planning on sending it to a friend since his integrated video is crapping out on him, he currently has a box with a athlon Thunderbird processor thats running at 1.4 gigs. Would it be possible that he could swap processors out and the motherboard would support his processor? Not sure how to check and see if the bios would support that either. Just thought I would ask.
That Barton core should be running a lot faster than 1.1 GHz. There is no Barton core CPU with that default frequency that I know of. I believe you have the BIOS set wrong, because it is being underclocked. Or maybe Cool 'N Quiet is enabled, if they even have that for Athlon XP (I don't remember). At any rate, the Barton is an upgrade from the Thunderboard. You would want the Barton core, NOT the T-Bird; it's much older.
I believe they are compatible. The only problem will could be the BIOS. But since we are talking about KT600 you should be fine. I remember KT400 was as high as I got before the move to A64 and I know I had several Bartons at work.
Ahh brings me back to the old days, I had a similar thunderbird build. I think it should work alright.
as said, the barton is miconfigured, it should run much faster, and AFAIK there is no cool 'n quiet on XPs
so in short, your friend shouldnt swap the CPU's, he should just use the KT600 board with the barton in it, once he configures the bios correctly he should have quite a nice boost in performance
thanks guys much obliged =) hard to find the right info one needs when its going back aways on the internet, but once again thanks!
That Barton is a 166 or 200 FSB chip. The motherboard might be set at the wrong multiplier or wrong FSB setting. Also, that motherboard might only be a 133 FSB motherboard.
Edit: it is a 200 mhz FSB motherboard. Check the FSB/multiplier settings.
cool 'n quiet came out with the socket 754 so you are correct there is no cool 'n quiet on that system..
like fuelvolts said.. the FSB is most likely set wrong.. maybe because the systems running PC-2100 ram instead of PC-2700 ram..
