CPU support question.
Argus
I am currently wanting to upgrade my cpu with an AMD 2400+ mobile. Now, the question is that I'm not sure if my motherboard GA-7VRXP (via KT333 chipset, rev 1.1) will support this cpu. I have the latest bios in it. The processor is 266fsb BUT is a barton, and that is why I'm not sure if its going to work.
This exact chip:
Barton
AXMH24004QQ4C
AQXEA 0323 MPMW
Y888463250142
Thank you in advance.
I bet it will work, but it'll say "unrecognized CPU type" on boot. The only way to find out is to try.
The BIOS probably won't have the microcode update for the Barton, but I doubt that will impair it's functionality.
check motherboard's website and see if the board supports barton - if so no problem with the mobile - if not , well it might be iffy
