CPU speed bottleneck sata SSD IOPS
Speedeu4ia
Windows 7 pro
3570k on Asrock Z77 extreme 4
850 EVO 500gb
Ive seen many reports of low power management setting being a cause of slow ssd performance. Most say switch to balanced performance power option and problem goes away. This test keeps power saving but alters only the processor speeds.
Test 1 is power saving setting, CPU min state 5% and max 50% keeps the CPU locked at 1600mhz (all C states are enabled) 1st pic
Test 2 same power save setting, cpu min state 100% and max 100% keeps the cpu locked at OC'd 4.3GHZ(same bios settings purely a windows change)
see pics 1 and 2
Random IOPS go from 71K/61K read/write to 98k/91k read/write
is the root cause of less IOPS due to CPU speed?
I guess Im just wondering if this is a real thing and of nvme drives act the same or can be bottlenecked by cpu
Can you tell any difference when you are actually using it for 'real stuff'?
If not, don't worry about it.
