whats the benefit of using a cpu shim?
i found a thermaltake cpu shim laying around...
should i use it with the XP 2400+? will it fit?
i know they can be used so you dont crush the cpu...
im installing a 2400+ on a new setup, and im wonder if i should use it or not...what are the pros/cons of using it??
btw, it looks like this
www.tweaknews.net/reviews/tsr/
