D
Deleted member 79192
Guest
After running Sisoft Sandra, I've noticed that my Pentium 3 750 MHrz Coppermine CPU is running at 26 degrees Celsius while idling. I am guessing I have some over-clocking capabilities there!...
Originally posted by Matt Welke
I don't have a thermometer in my room, but I knwos its pretty cold. I live in the basement.![]()
Originally posted by cornelious0_0
Yeah, so do I. I say pump that thing to its max.
Eww, wouldn't that be a little "sharp"?![]()
Pumping it to its max.....Anal Sex. Anal sex with a computer CPU might not feel too good, a little "sharp". Get it now?
AWWWWKKKward.
Originally posted by Bun-Bun
Awkward yet it becomes his sig...lol j/j
Originally posted by RS3RS
What's room temp (in C)? Chances are the sensor(s) are incorrect.
Originally posted by ChappyChaps11
37
Originally posted by Gabs
Unless its 37F in which case damn, your room is cold![]()
Please take that outta yur sig, or atleast my last name... Might be a little embarrassing if someone saw that (especially my parents).
By the way, its MY CPU that runs at 26C.
Go go speedracer
Originally posted by Munka
r u serios? u canot be serios
The thing is though, most people's CPUs run at around 50C! Mine is nowhere near that! Is this unhealthy to run so cool?
If mine was a tenth of the speed of others, "others" would have a 7.5 GHrz machine.
If my mobo doesn't have fixed PCI and AGP bus though, might not be that safe to overclock. I am upgrading to an Athlon XP 2600+ (Barton core) soon though. A lot of people say overclocking the Athlon XPs gives you a lot of extra performance because of the Instructions per Cycle thing, but I know exactly what my parents will say to overlocking it: "You'v got the fastest computer in the house, running at TWO THOUSAND MEGAHERTZ and you want to overclock it?!" Lol, they wouldn't even bother mentioning the extra cache and higher IPC, but thats their loss.
Originally posted by kronchev
look at performance, 750 PIII doesnt even get 1000 in Sandra I believe, while the standard is around 10k
Thats a performance rating, not a speed calculation. You can calculate speed in mhz.
So If you want to use something like that instead of straight mhz then choose a calculation. Like calculating pi to the 10 millionth digit. that will give you a time, which you can turn into a rate thus getting speed![]()
when someone says something is faster than something else, usually they mean in terms of performance, after all the intel-amd-ipc stuff.
I mean performance guys. But, a P3 gets 1000 in what? The standard what, is 10,000? What is this that yur talking about? THe Index value or something?
