MSI RS480M2-IL Radeon Xpress 200
AMD Athlon 64 3000+ Venice w/ retail HSF
Cooler Master CAV-T04-UWA Silver 300 W PSU(2x60, 1x80)
Windows MCE 2005
1 x 256 crucial ddr 2100 (yes, I know. I had it on hand though)
20 GB 4200rpm laptop HD
So I put together this build for my HTPC, thinking that the cool and quiet feature would solve most of my problems. But the mobo is reporting that the CPU is 55C so the fan isn't getting throttled down at all. What bothers me is not the temperature, but the heatsink isn't even warm. The northbridge HS is much hotter then the CPU, so I know I'm not crazy.
Are there known problems with this board or CPU/mobo combination?
Other thing wrong is that according to AMD's own Cool and Quiet util, the CPU is never throttling down. Its always running at 1.4(or is it 1.5?) volts and 1800 Mhz. I've installed the AMD CPU driver from AMD's site and I've turned on "minimal power something" from the screensaver menu.
Help would be appreciated!
Windows MCE 2005
