CPU Removal???
xFuryofFivex
when removing CPU fan,i used a screwdriver but the screwdriver slid off and hit the the motherboard, could that cause the motherboard to stop functioning???but still power up?
i think i also did this to another motherboard...
i get no video... i dont think its the videocard,could it possibly be that?
should i take both videocards out and test them in a computer that is running?
ok tested both videocards in a working computer... they work perfect...
wish i could say the same for the motherboards...
any help would be good... maybe asap ty
I did that a few years ago...gouged the mobo and severed a few traces...dead board. Look closely where you hit it (with a magnifying glass if necessary) and see if you hurt it or not.
I've done something similar to my current rigs mobo...dropped the screwdriver...luckily, no damage has been done. wish the same could've been for you.
That sucks man, I also did the same thing - about 10 years ago! It was a 386 system I was building, I severed a couple of traces and the mobo no worky no more. I was pretty bummed as it was my upgrade from the Zenith 286 that I was using at the time. I played the crap out of "Legend of the Red Dragon" on that 286 though..... :D
so the verdict is dead boards?
How are Biostar boards? or should i just stick with asus
have you looked (physically) at the board yet? If it looks okay, take the processor out and try ot turn it on. It should beep the beep code stating that there is no processor. Try the same with memory.
I've stabbed my old KT133 board multiple times with a screwdriver. FOP-38 heatsinks were not the most friendly things to work with. However, somehow, it still worked for many years.
Have you tried resetting the CMOS? Always a good thing to do before assuming it's dead. The reason no video is showing is because it's not completing POST, so yeah, vid cards are generally the first to take the blame but unlikely culprits. As stated above, make sure you're not getting any beep codes as well.
for one of them i reset the cmos and same thing, both of them dont beep at all.
i think i stabbed it pretty good then
i stabbed my asus A8n when i put it in with a phillips and it didn't do any damage, and it works perfectly. I got lucky
