I am looking to run 8 VM's and right now I am running 4 on an old dual core I have(4300 w/3.5gigs & 32bit XP), and it pretty much maxes out the CPU when I have all 4 running.
I am looking to possibly purchasing a new quad core and sticking it in there instead and jumping up to 8 gigs, and throwing some sort of 64bit OS on there. I am using VMWare and was wondering if just basic Intel quad core such as the Q8200 might get it done.
The recommendation for the software is 1gb and a 1.5ghz processor. You think I could run 8 on a Q8200. I get away with allocating 768mb per VM so the ram wouldn't be an issue, but not sure if each core could run 2 vms..
If you have any other suggestions let me know. I am sure this is pretty vague question, but thanks for your help.
