CPU Questions, need advice on Core 2 Duos
Furious911
Hey fellas, I'm excited finally building a system and actually on its way to being a reality, I really only need 2 more components, a CPU and a video card to get it working, I'm gonna save up and buy another video card ASAP but, how can I wait for 2 when I could get it working with 1, you know what I mean? lol anyway heres my question:
given that I have this motherboard: (EVGA nForce 680i SLI)
http://www.newegg.com/Product/Product.aspx...N82E16813188012
which supports FSB 1333/1066MHz and Memory Standard DDR2 1200
and this memory type: (3 gigs of Crucial Ballistix Tracer Dual Channel DDR2 800MHz (2 x 1024MB) & (2 x 512))
http://www.compusa.com/applications/Search...sp?Sku=C19-4502
which is obviously DDR2 800, nice speed tho, 4-4-4-12
NOTE one thing I realized is that the 2gig kit is SLI certified and the 1gig kit is Crossfire certified, um anyone know why that is? Think I'll have issues?
I'm trying to decide which CPU to get, this mobo supports a vast array of awesome stuff but I don't wanna get something that is bottlenecked by my ram or anything like that, I'm trying to decide if I should get a CPU with a FSB of 800, 1066 or 1333, any will be a Core 2 Duo. See I'm not sure if I'll see a real difference in games or if I'll be bottlenecked at all, and I can upgrade to something better later with better RAM too, just wanted to get some opinions on this.
FYI I plan to get dual 9600GTs, 1 at first then another about 3 months later for SLI action.
Thanks fellas!
$199 (at MicroCenter) Q6600, run your memory at 1:1, CPU @ 8x or 9x for 3.2 to 3.6 OC on the Q6600?
Im not sure what your saying but I'm not overclocking, I am putting a 3rd party heatsink and fan on it tho just in case.
Are you on drugs?
I am a little drunk right now, but check back tomorrow and I will give you a few pointers as to why I am asking that question.
Don the drunk geek.
Are you on drugs?
Don the drunk geek.
ROFL, wrong thread too.
This needs making into a siggy somehow :D
Drugs, alcohol, what's the dif?
I'm going to bed.
Don
HEHEHEHEHE
OP, you need to decide whether to go quad core or dual core.
The E8400/E8500 dual cores are very fast even at stock speeds, enough to drive a GTX to its max.
You will want higher speed than 3GHz to drive SLI though.
Quads arent clocked as high but for most things you dont really need a faster CPU as long as you are prepared to clock the quad.
fyi I have an E8400 clocked to 4GHz and it is smoking quick.
I havent seen a need for quad core yet, there are a few games which can use it but I havent felt the urge to buy them.
You need to decide what you want based on what you want to do and be prepared to do some overclocking if going quad core.
Alternatively wait a bit for Yorkfield Quads to be released as these are based on the same tech as the E8xx chips and will be clocked higher.
What I was saying is go to MicroCenter and buy a Q6600 for $199+tax out the door. It amazes me you can get a CPU like that for that money - the thing was like $850 14 months ago!
If you're definitely not going to OC, then get an E8400 or E8500 and run it @ stock I guess. But not buying a Q6600 and just running it at 3.0 or 3.2 and instead buying an E8400, paying $70 more for it and running it @ stock speed will make Baby Jesus cry.
From what I've read and what I hope to experience shortly when I assemble my Q6600, overclocking on the Q6600 G0 is pretty much a no-brainer with a decent aftermarket HS/fan setup in a roomy case with good airflow.
Ok, I am more sober now.
If you are not going to clock your Q6600, the stock cooler that comes with your CPU will work just fine. In fact it will work fine for a modest clock up to 2.8 or so. My Q6600 did 3 ghz at stock voltage with no problems although I have a Thermaltake Maxorb.
Your RAM is way overkill if you are not clocking also. You only need 533 mhz mem to run stock.
Unless you have a MOBO that does not allow you to adjust the FSB, it makes little sense not to clock your system.
Don
Don
QFT. You have two practical options: Keep the stock cooler OR Buy an aftermarket cooler and OC the shit out of it. You're wasting your money on a cooler if you don't OC. I can understand the intimidation associated with OCing (my first OC was done just a few shorts months ago), but honestly it's a ton easier than it used to be and there's little to no risk involved if you do a little research first.
well now that you mention it :D I have this CPU cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233001
So Maybe I can get a E8200 since its cheaper and overclock it to 3Ghz, I don't know I don't really want to but if its easy I can, also I was looking for a relatively cheap CPU, which the e8200 isn't as well (I was looking at like $150) that would use my ram and SLI Geforce 9600gt (that i don't have yet) effectively.
I guess I also noticed that Newegg isn't the cheapest when it comes to CPUs, where do you guys recommend?
Last quick question, anyone have any idea on that Ram question about the 2x1gig being SLI certified and the 2x512mb only being Crossfire certified?
Thanks fellas!!
Interesting design. You should be able to clock very well with that cooler.
How smooth is the joints between the copper heatpipes and the aluminum base plate?
Don
Certifying ram for SLI or Crossfire is a marketing gimmick.
Any ram will work on SLI, same for Crossfire.
DonDon, this is what I read in a review of the cooler:
"Heatsink Base:
The usable area of the Xigmatek HDT-S963 heatsink base is 34x38mm in size. Note how each of the three 6mm diameter copper heatpipes has been swaged into the aluminum base block. A light sanding gives the total surface a smooth consistent texture. The copper heatpipes have been pressed flat, not sanded... that would puncture the tubes. Surface roughness is on the order of ~32 microinches, which is considered good. The copper and aluminum surfaces are pretty flat in both axis. The thin voids between the copper and aluminum are easily filled by good quality thermal compound. The two screw holes are for the Intel mounting hardware to attach to."
That little fin that they show in that pic, actually goes the other way so that air will be pointed down onto other components on the board that may need slightly more heat. And I bought Arctic Silver 5.
Cool thanks. I was wondering how the made the flat spots on the heatpipes. Having the heatpipes in dirct contact with the heat spreader would work well, you would think. It has a 4 wire fan so the PWM MOBO fan controllers (like my P5K) can control the fan properly.
I might have to pick one up just to play with the it. The price is right.
Don
Hey fellas so a guy at work is making a computer too, about 2 months ago eh bought a E6750 and now hes upgrading (already heh) to a quad core and he wants to sell me that E6750 for $150 what are ppls thoughts about this CPU??
Offer him a buck and a quarter and see if he will bite. If not, tell him you got an eye on a Q6600 you are looking to clock!
They are currently going for a smidge under $200 bux off of Pricewatch.
Don
The thing is I know it works, hes got all the receipts from newegg, intel has a 2yr waranty, and its $40 less then the newegg price.
I know there will always be something better for just a little more money so I'm trying to not think that way, in fact the sooner/cheaper I buy a CPU the sooner I can get a 9600 and get this thing going.
What I was wondering is if it's actually a good CPU, ie will a 9600gt SLI bottleneck the CPU, will I need to OC it, will it OC easyly and stably in the logn run, etc.
Thanks fellas.
I can't vouch for the e6750 directly, but here are a couple of things to consider.
1) The e6750 has a 1333 FSB and a mult of 8. You need support from your MOBO above 1333 FSB to clock this chip.
2) you may see some CPU bottlenecking if you run games at lower resolutions.
3)It sounds like it is a retail chip. An decent cooler will help if you decide to clock. Your Xigmatek cooler should work good there.
4) 800Mhz memory in dual channel mode will get you to 1600 FSB without overclocking the memory.
5) A 1066 FSB chip like the Q6600 has a higher multiplyer, and will clock easier.
It sounds like an OK deal to me. But remember, the original owner is upgrading to a Quad!!! I am also very happy with my Q6600.
Don
