CPU Question.
vat
Hello,
I was wondering if Intel or AMD CPU has any metal in it? Thanks
Yes, any electronic product on the market is going to have some amount of metal in it.
What exactly do you mean? Obviously the heat spreader and pins are metal, and as far as the actual processor die is concerned I believe all the interconnects for the transistors are copper or some other type of conductive metal. Just out of curiosity why do you ask?
