CPU OC Giving Problems
  • Thread starter Deleted member 143938
  • Start date
D
Guest
Hey, I'm trying to get Prime stable but I believe my CPU keeps failing me and I don't know how to go about fixing it.
I'm pretty sure it's not my ram because I ran memtest for 8 hours with no errors.
On my previous DFI motherboard my opty could do 2.93 stable, with this ASUS it fails prime at 2.85 within 3 hours... I tried lowering the mhz one by one since 2.93 with no luck, 100+ mhz declock? Something is wrong I think
what are your ram timings set to? Also, what sort of temps are you getting at idle/load?
Not sure about temps, BIOS shows 32C. Timings are 4-4-4-12 (my previous ballistix did 292 mhz at 3-3-3-10, not clue what's up with corsair), but again, I don't think my memory could be the fault, because it passed memtest with 6 hours no errors
Where is your chipset voltage? A increase in that might help.
Can't increase it by how ever much you want in this mobo apperantly, you can "overvolt" (enabled/disabled switch) the NB to 1.6, which I already did.
might be in your best interest to find out then huh
I had a ballpark figure since the last time I checked a couple of weeks ago, I just didn't feel like downloading and then uninstalling speedfan again. But here it is: Idle 33C, load 56-57C
